Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
removing the antenna housing
Pièces
Aucune pièce spécifiée.
  1. Using the plastic opening tool, push the blade into the space between the case and lower cover. Turn the opening tool slightly, the lower cover will detach on that side.
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
  2. Remove the one T5 Torx screw
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
3 autre(s) ont terminé cette réparation.
Niklas Johnson
Membre depuis le 31/01/2012
1 117 Réputation
18 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 3,631
