Aller au contenu principal
Nexus One Secondary Microphone Replacement
Ce dont vous avez besoin
  1. Nexus One Secondary Microphone Replacement, Rear Cover: étape 1, image 1 de 2 Nexus One Secondary Microphone Replacement, Rear Cover: étape 1, image 2 de 2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Secondary Microphone Replacement: étape 2, image 1 de 1
    • The rear cover slides up and off.
  3. Nexus One Secondary Microphone Replacement, Battery: étape 3, image 1 de 1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Secondary Microphone Replacement: étape 4, image 1 de 1
    • Pull the battery up and out.
  5. Nexus One Secondary Microphone Replacement, Battery Housing: étape 5, image 1 de 1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Secondary Microphone Replacement: étape 6, image 1 de 2 Nexus One Secondary Microphone Replacement: étape 6, image 2 de 2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Secondary Microphone Replacement: étape 7, image 1 de 2 Nexus One Secondary Microphone Replacement: étape 7, image 2 de 2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Secondary Microphone Replacement: étape 8, image 1 de 2 Nexus One Secondary Microphone Replacement: étape 8, image 2 de 2
    • Pry the top tab of the battery housing.
  9. Nexus One Secondary Microphone Replacement: étape 9, image 1 de 2 Nexus One Secondary Microphone Replacement: étape 9, image 2 de 2
    • Pry the right side tab of the battery housing.
  10. Nexus One Secondary Microphone Replacement: étape 10, image 1 de 2 Nexus One Secondary Microphone Replacement: étape 10, image 2 de 2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Secondary Microphone Replacement, Secondary Microphone: étape 11, image 1 de 2 Nexus One Secondary Microphone Replacement, Secondary Microphone: étape 11, image 2 de 2
    • Using the spudger, pry upwards on the second microphone connector.
  12. Nexus One Secondary Microphone Replacement: étape 12, image 1 de 1
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
Niklas Johnson
Membre depuis le 01/31/12
1 207 Réputation
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 2,267
