Aller au contenu principal
Nexus Q NFC Antenna Replacement
Ce dont vous avez besoin
  1. Nexus Q NFC Antenna Replacement, Taoglas PU18 Wi-Fi Dual Band Antenna: étape 1, image 1 de 1
    • Squeeze and pull to pop the cap off of the Nexus Q.
  2. Nexus Q NFC Antenna Replacement: étape 2, image 1 de 2 Nexus Q NFC Antenna Replacement: étape 2, image 2 de 2
    • Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
    • Once the antenna is disconnected, simply pull it off the outside of the inner dome.
  3. Nexus Q NFC Antenna Replacement, Inner Dome Daughterboard: étape 3, image 1 de 1
    • Undo the ZIF connector by prying with a spudger.
  4. Nexus Q NFC Antenna Replacement: étape 4, image 1 de 1
    • Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
  5. Nexus Q NFC Antenna Replacement: étape 5, image 1 de 1
    • Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
  6. Nexus Q NFC Antenna Replacement: étape 6, image 1 de 1
    • Use a spudger to disconnect the daughterboard from the ZIF connector.
  7. Nexus Q NFC Antenna Replacement, NFC Antenna: étape 7, image 1 de 2 Nexus Q NFC Antenna Replacement, NFC Antenna: étape 7, image 2 de 2
    • Use a spudger to pry out the NFC antenna.
    • The antenna has two layers; be careful not to pry the two layers apart.
Alex Thomas
Membre depuis le 01/31/13
27 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 7-10, Maness Winter 2013 Membre de l'équipe Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 633
