Introduction
Use this guide to replace the front panel assembly.
Pièces
Aucune pièce nécessaire.
  1. Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Remove the rear panel from the Nexus S.
    • Remove the rear panel from the Nexus S.
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
    • Lift and remove the rear inner frame from the Nexus S.
    • Disconnect the following cables from their respective sockets on the motherboard:
      • Headphone jack cable
      • Digitizer cable connector
      • Camera/SIM board connector
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
    • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
    • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
    • Remove the three Phillips screws securing the motherboard to the front display assembly.
    • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
    • Lift and remove the motherboard.
    • Front panel assembly remains.
17 autre(s) ont terminé cette réparation.
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 6
Total : 13,744
