Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nexus S Rear Camera Replacement
Ce dont vous avez besoin
  1. Nexus S Rear Camera Replacement, Rear Panel: étape 1, image 1 de 1
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
    Demander à FixBot
    Ajouter un commentaire
  2. Nexus S Rear Camera Replacement: étape 2, image 1 de 1
    • Remove the rear panel from the Nexus S.
    Demander à FixBot
  3. Nexus S Rear Camera Replacement, Battery: étape 3, image 1 de 1
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
    Demander à FixBot
  4. Nexus S Rear Camera Replacement, SIM Card: étape 4, image 1 de 2 Nexus S Rear Camera Replacement, SIM Card: étape 4, image 2 de 2
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
    Demander à FixBot
  5. Nexus S Rear Camera Replacement, Rear Inner Frame: étape 5, image 1 de 1
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
    Demander à FixBot
  6. Nexus S Rear Camera Replacement: étape 6, image 1 de 1
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
    Demander à FixBot
  7. Nexus S Rear Camera Replacement: étape 7, image 1 de 2 Nexus S Rear Camera Replacement: étape 7, image 2 de 2
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
    Demander à FixBot
  8. Nexus S Rear Camera Replacement: étape 8, image 1 de 2 Nexus S Rear Camera Replacement: étape 8, image 2 de 2
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
    Demander à FixBot
  9. Nexus S Rear Camera Replacement: étape 9, image 1 de 1
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
    Demander à FixBot
  10. Nexus S Rear Camera Replacement: étape 10, image 1 de 1
    • Lift and remove the rear inner frame from the Nexus S.
    Demander à FixBot
  11. Nexus S Rear Camera Replacement, SIM Card Board: étape 11, image 1 de 1
    • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
    Demander à FixBot
  12. Nexus S Rear Camera Replacement: étape 12, image 1 de 3 Nexus S Rear Camera Replacement: étape 12, image 2 de 3 Nexus S Rear Camera Replacement: étape 12, image 3 de 3
    • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
    • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
    • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
    Demander à FixBot
  13. Nexus S Rear Camera Replacement: étape 13, image 1 de 1
    • Lift and remove the SIM Card board out of the Nexus S.
    Demander à FixBot
  14. Nexus S Rear Camera Replacement, Motherboard: étape 14, image 1 de 1
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
    Demander à FixBot
  15. Nexus S Rear Camera Replacement: étape 15, image 1 de 1
    • Repeat the same procedure as the previous step to disconnect the digitizer connector.
    Demander à FixBot
  16. Nexus S Rear Camera Replacement: étape 16, image 1 de 1
    • Use a plastic opening tool to pry the speaker connector (highlighted in red) from its socket on the motherboard.
    • Remove the three Phillips screws securing the motherboard to the inner assembly.
    Demander à FixBot
  17. Nexus S Rear Camera Replacement: étape 17, image 1 de 1
    • Lift and remove the motherboard from the Nexus S, minding any cables that may get caught.
    Demander à FixBot
  18. Nexus S Rear Camera Replacement, Rear Camera: étape 18, image 1 de 2 Nexus S Rear Camera Replacement, Rear Camera: étape 18, image 2 de 2
    • Use the edge of plastic opening tool to flip up the rear facing camera ZIF connector.
    Demander à FixBot
  19. Nexus S Rear Camera Replacement: étape 19, image 1 de 1
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to lift and remove the rear camera from the motherboard.
    Demander à FixBot
7 autres ont terminé cette réparation.
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 42
Total : 3,773
