Aller au contenu principal
Nexus S Speaker Replacement
Ce dont vous avez besoin
  1. Nexus S Speaker Replacement, Rear Panel: étape 1, image 1 de 1
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S Speaker Replacement: étape 2, image 1 de 1
    • Remove the rear panel from the Nexus S.
  3. Nexus S Speaker Replacement, Battery: étape 3, image 1 de 1
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S Speaker Replacement, SIM Card: étape 4, image 1 de 2 Nexus S Speaker Replacement, SIM Card: étape 4, image 2 de 2
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S Speaker Replacement, Rear Inner Frame: étape 5, image 1 de 1
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S Speaker Replacement: étape 6, image 1 de 1
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S Speaker Replacement: étape 7, image 1 de 2 Nexus S Speaker Replacement: étape 7, image 2 de 2
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S Speaker Replacement: étape 8, image 1 de 2 Nexus S Speaker Replacement: étape 8, image 2 de 2
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S Speaker Replacement: étape 9, image 1 de 1
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S Speaker Replacement: étape 10, image 1 de 1
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S Speaker Replacement, SIM Card Board: étape 11, image 1 de 1
    • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
  12. Nexus S Speaker Replacement: étape 12, image 1 de 3 Nexus S Speaker Replacement: étape 12, image 2 de 3 Nexus S Speaker Replacement: étape 12, image 3 de 3
    • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
    • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
    • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
  13. Nexus S Speaker Replacement: étape 13, image 1 de 1
    • Lift and remove the SIM Card board out of the Nexus S.
  14. Nexus S Speaker Replacement, Motherboard: étape 14, image 1 de 1
    • Disconnect the following cables from their respective sockets on the motherboard:
    • Headphone jack cable
    • Digitizer cable connector
    • Camera/SIM board connector
  15. Nexus S Speaker Replacement: étape 15, image 1 de 3 Nexus S Speaker Replacement: étape 15, image 2 de 3 Nexus S Speaker Replacement: étape 15, image 3 de 3
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
    • Make sure to pry on the connector and not the socket itself. Prying the socket may cause severe damage.
    • Repeat the procedure for the digitizer and rear camera/SIM board connectors.
  16. Nexus S Speaker Replacement: étape 16, image 1 de 1
    • Remove the three Phillips screws securing the motherboard to the front display assembly.
  17. Nexus S Speaker Replacement: étape 17, image 1 de 2 Nexus S Speaker Replacement: étape 17, image 2 de 2
    • Wedge the plastic opening tool near the bottom right corner of the motherboard and pry upwards to dislodge it from its recess.
    • Lift and remove the motherboard.
  18. Nexus S Speaker Replacement, Speaker: étape 18, image 1 de 1
    • Speaker remains.
    • Be careful, the earpiece part is united with the speaker, you could cut the flex.
7 autres ont terminé cette réparation.
3 commentaires
Where can I buy the speaker?
Fergal Daly - Réponse
Hi, I bought a replacement for my speaker(it's dead) but, the replacement did not come with an earpiece. Can I take the earpiece from my old one and attach it to the new one. I have some soldering experience.
makenova - Réponse
hey makenova,
I have the same problem. Did the soldering worked for you ?
Geert Meeusen -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 6
Total : 6,748
