Aller au contenu principal
Nike+ Sportband Screen Replacement
Ce dont vous avez besoin
  1. Nike+ Sportband Screen Replacement, External Case: étape 1, image 1 de 2 Nike+ Sportband Screen Replacement, External Case: étape 1, image 2 de 2
    • To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
  2. Nike+ Sportband Screen Replacement: étape 2, image 1 de 2 Nike+ Sportband Screen Replacement: étape 2, image 2 de 2
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Screen Replacement, Screen: étape 3, image 1 de 2 Nike+ Sportband Screen Replacement, Screen: étape 3, image 2 de 2
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Screen Replacement: étape 4, image 1 de 3 Nike+ Sportband Screen Replacement: étape 4, image 2 de 3 Nike+ Sportband Screen Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
  5. Nike+ Sportband Screen Replacement: étape 5, image 1 de 2 Nike+ Sportband Screen Replacement: étape 5, image 2 de 2
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Screen Replacement: étape 6, image 1 de 3 Nike+ Sportband Screen Replacement: étape 6, image 2 de 3 Nike+ Sportband Screen Replacement: étape 6, image 3 de 3
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
Daniel Burtner
Membre depuis le 02/15/16
101 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 9-9, Wilson Spring 2016 Membre de l'équipe IUPUI, Team 9-9, Wilson Spring 2016
IUPUI-WILSON-S16S9G9
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 256
