Aller au contenu principal
Nike SportWatch GPS Unit Replacement
Ce dont vous avez besoin
  1. Nike SportWatch GPS Unit Replacement, GPS Unit: étape 1, image 1 de 1
    • Using a size #000 Phillips screwdriver, remove the six 5 mm screws on the back of the device.
  2. Nike SportWatch GPS Unit Replacement: étape 2, image 1 de 1
    • Then, gently pull the watch band and front screen apart.
  3. Nike SportWatch GPS Unit Replacement: étape 3, image 1 de 1
    • Using a size #000 Phillips screwdriver, remove the two 2.5 mm screws on the main board.
  4. Nike SportWatch GPS Unit Replacement: étape 4, image 1 de 1
    • Carefully, use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and is not removable.
  5. Nike SportWatch GPS Unit Replacement: étape 5, image 1 de 1
    • Use a spudger, to remove the orange tape that covers the wire for the GPS.
  6. Nike SportWatch GPS Unit Replacement: étape 6, image 1 de 1
    • Using the soldering iron, break the wire connecting the GPS to the main board at the connector.
    • When you are reassembling the watch, you will have to solder the wire back together.
  7. Nike SportWatch GPS Unit Replacement: étape 7, image 1 de 1
    • Use the plastic opening tool to pry out the GPS unit.
Ian Eichorn
Membre depuis le 10/22/15
678 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Membre de l'équipe UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 membres
5 tutoriels rédigés
3 commentaires
which GPS unit is it?
charles - Réponse
what gps unit is it?
charles - Réponse
I would also like to know what GPS unit that is and if it is possible to find a replacement or a compatible unit?
avs4820 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 1,890
