Introduction
The seal in the internal body of the camera is part of what keeps water and other detrimental particles out of the camera. This guide will show you how to replace a weathered one.
Ce dont vous avez besoin
Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
Use a Phillips PH00 screwdriver to remove the 3.8mm screw in red.
Use a Phillips PH00 screwdriver to remove the 4.9mm screw in orange.
Use a Torx T4 screwdriver to remove the four 5.5mm screws in yellow.
Presque terminé !
