Aller au contenu principal
Nikon 1 AW 1 Internal Body Seal Replacement
Ce dont vous avez besoin
  1. Nikon 1 AW 1 Internal Body Seal Replacement, Buttons: étape 1, image 1 de 3 Nikon 1 AW 1 Internal Body Seal Replacement, Buttons: étape 1, image 2 de 3 Nikon 1 AW 1 Internal Body Seal Replacement, Buttons: étape 1, image 3 de 3
    • Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
  2. Nikon 1 AW 1 Internal Body Seal Replacement: étape 2, image 1 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 2, image 2 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 2, image 3 de 3
    • Using the Phillips PH00 screwdriver, remove the four 5.5mm screws in the red circles. Then use a plastic opening tool to pry off the tripod socket.
    • Remove the metal plate to have access to the 4.9mm screw under the orange circle, use the Phillips PH00 screwdriver to remove it.
  3. Nikon 1 AW 1 Internal Body Seal Replacement: étape 3, image 1 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 3, image 2 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 3, image 3 de 3
    • Using a T4 head screwdriver remove the three 5.4mm screws marked with the red circles.
    • Use a 1/4" flathead screwdriver or a flat head tool to release the grip attachment screw.
    • Remove the camera strap eyelet.
  4. Nikon 1 AW 1 Internal Body Seal Replacement: étape 4, image 1 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 4, image 2 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 4, image 3 de 3
    • Remove the grip attachment screw.
    • Use a Phillips PH00 to remove the two 2.4mm screws on the grip attachment slot, then remove the slot.
  5. Nikon 1 AW 1 Internal Body Seal Replacement: étape 5, image 1 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 5, image 2 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 5, image 3 de 3
    • Use a T4 screwdriver to remove the three 5.4mm screw marked with the red circles and the eyelet strap.
    • Use a plastic opening tool to lift the front camera cover off.
  6. Nikon 1 AW 1 Internal Body Seal Replacement: étape 6, image 1 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 6, image 2 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 6, image 3 de 3
    • Use a Phillips PH00 to unscrew the two 3.5mm screws in red.
    • Press the flash pop-up button in the orange rectangle to be able to remove top cover of the camera.
  7. Nikon 1 AW 1 Internal Body Seal Replacement: étape 7, image 1 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 7, image 2 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 7, image 3 de 3
    • Use a plastic opening tool to lift off the top panel.
  8. Nikon 1 AW 1 Internal Body Seal Replacement: étape 8, image 1 de 1
    • If you needed to replace any buttons, you may now do so by pulling them off.
  9. Nikon 1 AW 1 Internal Body Seal Replacement, Internal Body Seal: étape 9, image 1 de 3 Nikon 1 AW 1 Internal Body Seal Replacement, Internal Body Seal: étape 9, image 2 de 3 Nikon 1 AW 1 Internal Body Seal Replacement, Internal Body Seal: étape 9, image 3 de 3
    • Use a Phillips PH00 screwdriver to remove the 3.8mm screw in red.
    • Use a Phillips PH00 screwdriver to remove the 4.9mm screw in orange.
    • Use a Torx T4 screwdriver to remove the four 5.5mm screws in yellow.
  10. Nikon 1 AW 1 Internal Body Seal Replacement: étape 10, image 1 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 10, image 2 de 3 Nikon 1 AW 1 Internal Body Seal Replacement: étape 10, image 3 de 3
    • Separate rear panel from the camera main body, starting from the HDMI and USB connector side. Do NOT pull the rear panel completely off of the camera yet.
    • Use a plastic opening tool to pry out the connector marked in red.
  11. Nikon 1 AW 1 Internal Body Seal Replacement: étape 11, image 1 de 2 Nikon 1 AW 1 Internal Body Seal Replacement: étape 11, image 2 de 2
    • Use the plastic opening tool to pull out the old seal from the groove in the rear panel.
    • If you needed to replace the seal, you may now do so.
Daniel Heshmaty
Membre depuis le 10/04/16
397 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Sullivan Fall 2016 Membre de l'équipe USF Tampa, Team 3-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G4
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 9
Total : 553
