Aller au contenu principal
Nikon 1 AW 1 LCD Screen Replacement
Ce dont vous avez besoin
  1. Nikon 1 AW 1 LCD Screen Replacement, Buttons: étape 1, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement, Buttons: étape 1, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement, Buttons: étape 1, image 3 de 3
    • Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
  2. Nikon 1 AW 1 LCD Screen Replacement: étape 2, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 2, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 2, image 3 de 3
    • Using the Phillips PH00 screwdriver, remove the four 5.5mm screws in the red circles. Then use a plastic opening tool to pry off the tripod socket.
    • Remove the metal plate to have access to the 4.9mm screw under the orange circle, use the Phillips PH00 screwdriver to remove it.
  3. Nikon 1 AW 1 LCD Screen Replacement: étape 3, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 3, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 3, image 3 de 3
    • Using a T4 head screwdriver remove the three 5.4mm screws marked with the red circles.
    • Use a 1/4" flathead screwdriver or a flat head tool to release the grip attachment screw.
    • Remove the camera strap eyelet.
  4. Nikon 1 AW 1 LCD Screen Replacement: étape 4, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 4, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 4, image 3 de 3
    • Remove the grip attachment screw.
    • Use a Phillips PH00 to remove the two 2.4mm screws on the grip attachment slot, then remove the slot.
  5. Nikon 1 AW 1 LCD Screen Replacement: étape 5, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 5, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 5, image 3 de 3
    • Use a T4 screwdriver to remove the three 5.4mm screw marked with the red circles and the eyelet strap.
    • Use a plastic opening tool to lift the front camera cover off.
  6. Nikon 1 AW 1 LCD Screen Replacement: étape 6, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 6, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 6, image 3 de 3
    • Use a Phillips PH00 to unscrew the two 3.5mm screws in red.
    • Press the flash pop-up button in the orange rectangle to be able to remove top cover of the camera.
  7. Nikon 1 AW 1 LCD Screen Replacement: étape 7, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 7, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 7, image 3 de 3
    • Use a plastic opening tool to lift off the top panel.
  8. Nikon 1 AW 1 LCD Screen Replacement: étape 8, image 1 de 1
    • If you needed to replace any buttons, you may now do so by pulling them off.
  9. Nikon 1 AW 1 LCD Screen Replacement, Internal Body Seal: étape 9, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement, Internal Body Seal: étape 9, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement, Internal Body Seal: étape 9, image 3 de 3
    • Use a Phillips PH00 screwdriver to remove the 3.8mm screw in red.
    • Use a Phillips PH00 screwdriver to remove the 4.9mm screw in orange.
    • Use a Torx T4 screwdriver to remove the four 5.5mm screws in yellow.
  10. Nikon 1 AW 1 LCD Screen Replacement: étape 10, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 10, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 10, image 3 de 3
    • Separate rear panel from the camera main body, starting from the HDMI and USB connector side. Do NOT pull the rear panel completely off of the camera yet.
    • Use a plastic opening tool to pry out the connector marked in red.
  11. Nikon 1 AW 1 LCD Screen Replacement: étape 11, image 1 de 2 Nikon 1 AW 1 LCD Screen Replacement: étape 11, image 2 de 2
    • Use the plastic opening tool to pull out the old seal from the groove in the rear panel.
    • If you needed to replace the seal, you may now do so.
  12. Nikon 1 AW 1 LCD Screen Replacement, Rear Panel: étape 12, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement, Rear Panel: étape 12, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement, Rear Panel: étape 12, image 3 de 3
    • Use a Phillips PH00 screwdriver to remove the seven 3.1mm screws marked in red.
    • Use a Phillips PH00 screwdriver to remove the two 3.6mm screws marked in orange.
    • Lift off the small plate as shown.
  13. Nikon 1 AW 1 LCD Screen Replacement: étape 13, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 13, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 13, image 3 de 3
    • Lift the rainbow cable to have access to the 3.1mm screw beneath it and unscrew it with a Phillips PH00 screwdriver.
    • Turn aside the LCD screen but do not completely remove it yet.
    • You will need to lift the sticky patch inside the the yellow rectangle, to access the 3.1mm screw marked in orange, remove it with Phillips PH00 screwdriver, then you will be able to separate the LCD screen from the rear panel.
  14. Nikon 1 AW 1 LCD Screen Replacement: étape 14, image 1 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 14, image 2 de 3 Nikon 1 AW 1 LCD Screen Replacement: étape 14, image 3 de 3
    • Remove the back panel apart from LCD screen.
3 autres ont terminé cette réparation.
Daniel Heshmaty
Membre depuis le 10/04/16
397 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 3-4, Sullivan Fall 2016 Membre de l'équipe USF Tampa, Team 3-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G4
4 membres
6 tutoriels rédigés
1 commentaire de tutoriel
Great thanks! Where can I order the screen?
terrykosick - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 17
Total : 974
