Aller au contenu principal
Nikon 1 J3 LCD Screen Replacement
Ce dont vous avez besoin
  1. Nikon 1 J3 LCD Screen Replacement, LCD Screen: étape 1, image 1 de 2 Nikon 1 J3 LCD Screen Replacement, LCD Screen: étape 1, image 2 de 2
    • Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
    • Remove the screws under the flaps covering the HDMI and mini USB ports.
  2. Nikon 1 J3 LCD Screen Replacement: étape 2, image 1 de 1
    • Carefully pry back the back plate.
    • The plastic of the back plate may crack.
  3. Nikon 1 J3 LCD Screen Replacement: étape 3, image 1 de 1
    • Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
  4. Nikon 1 J3 LCD Screen Replacement: étape 4, image 1 de 1
    • Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
Austin Lackey
Membre depuis le 09/26/17
479 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S11-G4, Passmore Fall 2017 Membre de l'équipe USF Tampa, Team S11-G4, Passmore Fall 2017
USFT-PASSMORE-F17S11G4
3 membres
4 tutoriels rédigés
3 commentaires
Hey, I’m having trouble removing the back plate on step 2. It seems to be stuck on the side opposite the HDMI and USB ports, any tips for removing it? Thanks!
johnjames460 - Réponse
Step 1 seems to mis removal of 2 screws. Check tutorial below:
https://www.lifepixel.com/tutorials/infr...
Marcel Rossewij - Réponse
I am about to replace the lcd screen on my J4 - is the method the same as for the J3? And do I need any adhesive?
Nicholas Glover - 2nd April 2023
Nicholas Glover - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 1,174
