Introduction
En suivant ces neuf étapes simples, on peut remplacer avec succès la molette de sélection multiple de l'appareil photo Nikon COOLPIX P7700 après avoir retiré le boîtier.
Ce dont vous avez besoin
Tournez la caméra vers la gauche et retirez les deux vis latérales noires de 4,3 mm à l'aide du tournevis cruciforme # 00.
Retirez le panneau latéral.
Retirez les quatre vis de 4,3 mm situées sur la plaque métallique à l'extrême droite. Utilisez le tournevis cruciforme # 00.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
7 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
8 commentaires
Step 9: I believe that the multi-selector wheel component is soldered, 3 wires just visible in the photo for step 8. This will surely add to the time taken and difficulty.
I have a problem with this component. Firstly it's almost impossible to obtain the replacement parts, but if I could this guide would be invaluable; pictures are worth a thousand words! Thanks.
where can I get the item ( wheel ) ?
Best regards and thank you for the good explanation
Where i can find this wheel for replacement?
Please see my comment on the "general" method of fixing the wheel (using fast-drying contact cleaner) without ANY component replacement or unscrewing. It works really well but you may have to do it 1-3 times until all the dirt inside the wheel mechanism is removed. I have managed to restore my P7700 (after "fixing" the erratic Control Wheel and the dis-obedient Play button). Since then I have used the same method to fix the control wheel on my Samsung EX-1 camera (the control wheel was replaced twice by Samsung but the problem came back after a year or so). The root cause is probably a weak control wheel design (maybe tiny metal springs rotating over a base-plate with printed circuits). Now I know how to save money and trouble (for any compact camera with a similar control wheel design).
