Aller au contenu principal
Nikon COOLPIX S610c LCD Replacement
Ce dont vous avez besoin
  1. Nikon COOLPIX S610c LCD Replacement, Battery: étape 1, image 1 de 1
    • On the bottom right of the camera, locate the battery flap switch.
  2. Nikon COOLPIX S610c LCD Replacement: étape 2, image 1 de 1
    • Move this switch to the right so the battery flap can flip open.
  3. Nikon COOLPIX S610c LCD Replacement: étape 3, image 1 de 1
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Nikon COOLPIX S610c LCD Replacement, Rear Casing: étape 4, image 1 de 1
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Nikon COOLPIX S610c LCD Replacement: étape 5, image 1 de 1
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Nikon COOLPIX S610c LCD Replacement: étape 6, image 1 de 1
    • Pry the panel off from the bottom using your fingernail.
  7. Nikon COOLPIX S610c LCD Replacement: étape 7, image 1 de 1
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Nikon COOLPIX S610c LCD Replacement: étape 8, image 1 de 2 Nikon COOLPIX S610c LCD Replacement: étape 8, image 2 de 2
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Nikon COOLPIX S610c LCD Replacement: étape 9, image 1 de 2 Nikon COOLPIX S610c LCD Replacement: étape 9, image 2 de 2
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Nikon COOLPIX S610c LCD Replacement: étape 10, image 1 de 2 Nikon COOLPIX S610c LCD Replacement: étape 10, image 2 de 2
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
  11. Nikon COOLPIX S610c LCD Replacement, LCD: étape 11, image 1 de 2 Nikon COOLPIX S610c LCD Replacement, LCD: étape 11, image 2 de 2
    • Pry the display from the rear casing using a spudger.
Kevin Backers
Membre depuis le 01/26/12
301 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 9-5, Regan Winter 2012 Membre de l'équipe Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
5 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 561
