Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nikon CoolPix P310 Sensor Replacement or Cleaning
Ce dont vous avez besoin
    • Remove all screws from the bottom, sides and top of the camera. All screws don't have the same size, be careful when replacing them.
    • Pull gently but firmly the back cover of the camera to remove it and reveal the inside.
    Demander à FixBot
    Ajouter un commentaire
  1. Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the button block and screen: étape 2, image 1 de 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the button block and screen: étape 2, image 2 de 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the button block and screen: étape 2, image 3 de 3
    • Remove the plastic part with all buttons.
    • Lift up the the buttons block from the left side, to access its ZIF connector.
    Demander à FixBot
  2. Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the button block and screen: étape 3, image 1 de 2 Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the button block and screen: étape 3, image 2 de 2
    • With a plastic spudger, open the ZIF connector and release the button block. It opens from the right side - the black part is to be gently lifted up.
    Demander à FixBot
  3. Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the Screen: étape 4, image 1 de 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the Screen: étape 4, image 2 de 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Removing the Screen: étape 4, image 3 de 3
    • Lift up the screen from the left side, to access its two ZIF connectors.
    • Open the small and the large ZIF connectors with a spudger.
    • The small connector is opened by lifting the black part.
    • The large connector is released thanks to the orange part. This longer connector needs to be opened carefully.
    Demander à FixBot
  4. Nikon CoolPix P310 Sensor Replacement or Cleaning, Accessing the main PCB: étape 5, image 1 de 2 Nikon CoolPix P310 Sensor Replacement or Cleaning, Accessing the main PCB: étape 5, image 2 de 2
    • Remove the screws maintaining the last metal protection.
    Demander à FixBot
  5. Nikon CoolPix P310 Sensor Replacement or Cleaning, Releasing the image sensor: étape 6, image 1 de 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Releasing the image sensor: étape 6, image 2 de 3 Nikon CoolPix P310 Sensor Replacement or Cleaning, Releasing the image sensor: étape 6, image 3 de 3
    • Remove the 3 screws to release the image sensor PCB.
    • Release the ZIF connector lifting it up gently using a plastic spudger.
    • You can then remove the image sensor and clean it. Avoid to scratch the sensor or the inner lens glass, as these would be unrepairable damages.
    Demander à FixBot
AlexFixeurs
Membre depuis le 06/20/15
1 657 Réputation
4 tutoriels rédigés
Équipe
Fixeurs Membre de l'équipe Fixeurs
Business
1 membre
7 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 47
Total : 1,520
