Aller au contenu principal
Nikon CoolPix S600 Lens Assembly Replacement
Ce dont vous avez besoin
  1. Nikon CoolPix S600 Lens Assembly Replacement, Front and Rear Casing: étape 1, image 1 de 1
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 Lens Assembly Replacement: étape 2, image 1 de 1
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 Lens Assembly Replacement: étape 3, image 1 de 1
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 Lens Assembly Replacement: étape 4, image 1 de 2 Nikon CoolPix S600 Lens Assembly Replacement: étape 4, image 2 de 2
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 Lens Assembly Replacement: étape 5, image 1 de 2 Nikon CoolPix S600 Lens Assembly Replacement: étape 5, image 2 de 2
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 Lens Assembly Replacement: étape 6, image 1 de 1
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 Lens Assembly Replacement: étape 7, image 1 de 1
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 Lens Assembly Replacement: étape 8, image 1 de 2 Nikon CoolPix S600 Lens Assembly Replacement: étape 8, image 2 de 2
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 Lens Assembly Replacement: étape 9, image 1 de 1
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 Lens Assembly Replacement: étape 10, image 1 de 3 Nikon CoolPix S600 Lens Assembly Replacement: étape 10, image 2 de 3 Nikon CoolPix S600 Lens Assembly Replacement: étape 10, image 3 de 3
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
  11. Nikon CoolPix S600 Lens Assembly Replacement, Lens Assembly: étape 11, image 1 de 2 Nikon CoolPix S600 Lens Assembly Replacement, Lens Assembly: étape 11, image 2 de 2
    • From the top view of the camera, remove the one 5.8 mm screw.
    • From the top view of the camera, remove the one 2.8 mm screw
  12. Nikon CoolPix S600 Lens Assembly Replacement: étape 12, image 1 de 1
    • Remove the three 3.4 mm screws from the back side of the camera.
  13. Nikon CoolPix S600 Lens Assembly Replacement: étape 13, image 1 de 1
    • Remove the two 3.4 mm screws from the side of the camera.
  14. Nikon CoolPix S600 Lens Assembly Replacement: étape 14, image 1 de 1
    • Separate the two metal body pieces from the rest of the camera.
  15. Nikon CoolPix S600 Lens Assembly Replacement: étape 15, image 1 de 2 Nikon CoolPix S600 Lens Assembly Replacement: étape 15, image 2 de 2
    • Gently remove the two ribbons connecting the lens to the mother board.
  16. Nikon CoolPix S600 Lens Assembly Replacement: étape 16, image 1 de 2 Nikon CoolPix S600 Lens Assembly Replacement: étape 16, image 2 de 2
    • Gently separate the camera lens from the mother board.
2 autres ont terminé cette réparation.
andreas anggasastra
Membre depuis le 09/14/11
116 Réputation
5 tutoriels rédigés
Équipe
Cuesta, Team 1-6, Zipperian Fall 2011 Membre de l'équipe Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
2 membres
6 tutoriels rédigés
Un commentaire
Any place where I could buy a new lens for the camera nowadays?
thesilver - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 3,237
