Introduction
Use this guide to replace the LCD.
Pièces
Aucune pièce nécessaire.
  1. Remove the four 3.0mm screws on the bottom of the camera.
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
    • Remove the two 3.0mm screws on the right side of the camera.
    • Carefully open the back cover. Take care as there are connectors still attached.
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
    • First remove the three 2.5mm screws securing the LCD screen to the substrate. Make sure not to keep hold of the little metal connector by the top left screw!
    • Carefully flip the screen down to reveal the back of the screen
    • Disconnect the ribbon cable and gray connector with red and black wires.
    • Depending on your spare part, you may now need to carefully pry the screen back cover off. It is held by a double sided sticky tape on the inside. Be gentle!
Kaky Payne
Membre depuis le 17/04/2012
58 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 12-38, Regan Spring 2012 Membre de l'équipe Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,045
