Aller au contenu principal
Introduction
This iFixit guide shows you how to disassemble the Nikon Coolpix 995 camera, and remove/replace the LCD display.
Pièces
Aucune pièce spécifiée.
  1. Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws, Remove the two screws with a Phillips #00 screwdriver.
    • Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
    • Remove the two screws with a Phillips #00 screwdriver.
    • Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
    • Refer to the second image to locate the second set of screws. The relevant screws are highlighted in red.
  2. Flip the camera up-side down.
    • Flip the camera up-side down.
    • Remove the two Phillips #00 screws located near the battery compartment.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. Open  the memory card compartment cover.
    • Open the memory card compartment cover.
    • You can now see four screws under the cover. Remove all four screws.
    • Refer to the image to locate the four screws. Make sure that you remove only the four screws identified in the image.
  5. Use your thumb to carefully lift the bottom side of the casing near the battery. Pay attention to a cable located at the top of the assembly, as it is prone to breakage. Refer to the second image to locate the cable.
    • Use your thumb to carefully lift the bottom side of the casing near the battery.
    • Pay attention to a cable located at the top of the assembly, as it is prone to breakage. Refer to the second image to locate the cable.
  6. Use a spudger to flip the tabs that hold the screen.
    • Use a spudger to flip the tabs that hold the screen.
    • Refer to the image for more details. The tabs are circled in red.
  7. Carefully lift the LCD from the bottom. It should come out fairly easily.
    • Carefully lift the LCD from the bottom. It should come out fairly easily.
Cory Layman
Membre depuis le 04/10/2011
89 Réputation
3 tutoriels rédigés
Équipe
UW Stout, Team 1-5, Zhou Fall 2011 Membre de l'équipe UW Stout, Team 1-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G5
5 membres
3 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 1,843
