Aller au contenu principal
Nikon Coolpix L27 Screen Replacement
Ce dont vous avez besoin
  1. Nikon Coolpix L27 Screen Replacement, Screen: étape 1, image 1 de 3 Nikon Coolpix L27 Screen Replacement, Screen: étape 1, image 2 de 3 Nikon Coolpix L27 Screen Replacement, Screen: étape 1, image 3 de 3
    • Undo the latch at the bottom of the camera by pushing it to the side
    • Remove the batteries (and memory card if applicable)
  2. Nikon Coolpix L27 Screen Replacement: étape 2, image 1 de 2 Nikon Coolpix L27 Screen Replacement: étape 2, image 2 de 2
    • Remove the two 5 mm Phillips #000 screws from the left side.
  3. Nikon Coolpix L27 Screen Replacement: étape 3, image 1 de 3 Nikon Coolpix L27 Screen Replacement: étape 3, image 2 de 3 Nikon Coolpix L27 Screen Replacement: étape 3, image 3 de 3
    • Lift the cover labeled "A/V OUT" to expose a hidden screw.
    • Remove two 5 mm Phillips #000 screws from the bottom of the camera.
  4. Nikon Coolpix L27 Screen Replacement: étape 4, image 1 de 2 Nikon Coolpix L27 Screen Replacement: étape 4, image 2 de 2
    • Remove the two 5 mm Phillips #000 screws from the right side of the camera.
  5. Nikon Coolpix L27 Screen Replacement: étape 5, image 1 de 3 Nikon Coolpix L27 Screen Replacement: étape 5, image 2 de 3 Nikon Coolpix L27 Screen Replacement: étape 5, image 3 de 3
    • Carefully pry the back cover starting from the battery latch.
    • Once all sides are loose, lift the back cover up and off.
  6. Nikon Coolpix L27 Screen Replacement: étape 6, image 1 de 1
    • Carefully lift the LCD screen up towards the bottom of the camera.
    • The LCD is connected to a cable so don't pull it out yet.
  7. Nikon Coolpix L27 Screen Replacement: étape 7, image 1 de 1
    • Lightly push back the white switch holding in the screen cable
  8. Nikon Coolpix L27 Screen Replacement: étape 8, image 1 de 2 Nikon Coolpix L27 Screen Replacement: étape 8, image 2 de 2
    • Remove the cable from the camera.
    • Lift the screen out.
Vishalpreet Sandhu
Membre depuis le 01/18/22
157 Réputation
1 tutoriel rédigé
Équipe
York University, Team R-25, Melo-Thaiss Winter 2022 Membre de l'équipe York University, Team R-25, Melo-Thaiss Winter 2022
YORK-MELO-THAISS-W22SRG25
1 membre
1 tutoriel rédigé
Un commentaire
would you know how to replace the little button battery just next to the screen, because the Lense is not retracting anymore?
Walter D. - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 49
Total : 663
