Introduction
The CCD sensor can be sensitive to scratches and other contaminants that would disrupt its surface yielding blurry images. This guide will provide the procedure necessary to replace this component.
Ce dont vous avez besoin
Remove the six 4mm screws highlighted in red with the Phillips #000 screwdriver.
Remove the 5mm screw highlighted in orange with the Phillips #000 screwdriver.
Pop up the camera flash using the button below the lightning bolt on the left side of the camera.
Identify the small notch below the camera flash where the body of the camera and the back cover join.
Use plastic opening tools to pry the darker plastic piece under the camera flash from the lighter plastic camera body.
Outil utilisé dans cette étape :Tweezers$4.99
Gently lift the back cover away from the camera body.
A gold ribbon cable will join the back cover of the camera to the internal electronic components. Be careful not to remove the back cover without removing the cable since this part can easily break.
To remove the ribbon cable, gently pull the connector from the camera's internal electronic components using a pair of tweezers.
Remove the six 4mm screws highlighted in red using the Philips #000 screwdriver.
Remove the 6mm screw highlighted in orange using the Philips #000 screwdriver.
Disconnect the ribbon cable connector by prying upwards on the part using the plastic opening tools.
2 autres ont terminé cette réparation.
