Aller au contenu principal
Nikon Coolpix P90 Flash Bulb Replacement
Ce dont vous avez besoin
  1. Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: étape 1, image 1 de 3 Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: étape 1, image 2 de 3 Nikon Coolpix P90 Flash Bulb Replacement, Camera Base: étape 1, image 3 de 3
    • Use your finger to push the latch of the compartment door to the center of the camera body, per image 1.
    • Push the door open, and remove the existing battery with your fingers, per images 2-3.
  2. Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: étape 2, image 1 de 2 Nikon Coolpix P90 Flash Bulb Replacement, Flash Bulb: étape 2, image 2 de 2
    • Press the button on the side of the body to open the flash compartment.
  3. Nikon Coolpix P90 Flash Bulb Replacement: étape 3, image 1 de 1
    • Using a Phillips #000 Precision Screwdriver, remove the two 3.0 mm screws from inside the compartment.
  4. Nikon Coolpix P90 Flash Bulb Replacement: étape 4, image 1 de 1
    • Place the plastic opening tool along the crack on the side of the flash compartment cover and pry open and detach the cover.
  5. Nikon Coolpix P90 Flash Bulb Replacement: étape 5, image 1 de 2 Nikon Coolpix P90 Flash Bulb Replacement: étape 5, image 2 de 2
    • Using a Phillips #000 Precision Screwdriver, remove the 4.0 mm screw from the plastic cover.
    • Detach the plastic cover.
  6. Nikon Coolpix P90 Flash Bulb Replacement: étape 6, image 1 de 2 Nikon Coolpix P90 Flash Bulb Replacement: étape 6, image 2 de 2
    • Carefully remove the flash bulb holder with your fingers.
  7. Nikon Coolpix P90 Flash Bulb Replacement: étape 7, image 1 de 1
    • Using the plastic opening tool, pry the metal bulb frame out of the socket.
  8. Nikon Coolpix P90 Flash Bulb Replacement: étape 8, image 1 de 1
    • Remove the plastic stoppers on either side of the metal flash bulb tray.
  9. Nikon Coolpix P90 Flash Bulb Replacement: étape 9, image 1 de 1
    • Using a soldering iron, desolder each of the wires connected to the light bulb.
    • Be careful! The soldering iron is hot. Do not burn yourself or the device. It should not be applied to the device too long to avoid damaging any of the device components.
    • For a comprehensive guide on desoldering, visit iFixit's Soldering and Desoldering Guide.
Elizabeth Kamine
Membre depuis le 01/22/15
655 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 20-14, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 879
