Aller au contenu principal
Introduction
You will be desoldering the circuit board of the camera.
  1. Place thumb on the battery cover panel on the bottom of the device.
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Slide the orange latch outward towards the corner of the camera. The battery should pop out.
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Unscrew the two 4.05mm screws on the side next to the buttons.
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Fix Kits pour iPhone X
    Finie la garantie ? Pas de soucis, nous avons de quoi réparer.
    Acheter maintenant
    Acheter maintenant
  7. Gently wedge the flat end of the spudger between the back case and the wrist-strap mount. The wrist-strap mount is the thin metal piece on the side of the camera.  Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  8. Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon. The ribbons are connected to and held in place by small plastic latches. To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up.  The ribbon should slide out easily.
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  9. Gently remove the LCD screen.
    • Gently remove the LCD screen.
  10. After removing the LCD screen, unscrew the four 3.8mm screws that hold down the metal plate
    • After removing the LCD screen, unscrew the four 3.8mm screws that hold down the metal plate
    • Unscrew the 2.5mm screw next to the wrist-strap mount.
  11. Position the camera with the lens facing down and the shutter button facing you. Lift the metal plate away from the camera without removing it fully.  There is a ribbon attaching the edge of the plate to the camera.
    • Position the camera with the lens facing down and the shutter button facing you.
    • Lift the metal plate away from the camera without removing it fully. There is a ribbon attaching the edge of the plate to the camera.
    • The ribbon is being held in place by a black latch.
    • Carefully pry the spudger under the black latch and lift gently upward. The ribbon will slide out easily.
    • With the ribbon unlatched, the entire metal plate should now be detached.
  12. Desolder the marked areas.  For desoldering instructions go -here-
    • Desolder the marked areas. For desoldering instructions go -here-
  13. Place the spudger underneath the small black tape as shown.  Gently lift the spudger up to remove the tape.
    • Place the spudger underneath the small black tape as shown. Gently lift the spudger up to remove the tape.
  14. Remove the 3.8mm screw from the circuit board. Desolder the marked areas.
    • Remove the 3.8mm screw from the circuit board.
John Bowers
Membre depuis le 18/01/2011
853 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 5-17, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 membres
7 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 3,280
