Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
  1. You will need a #00 phillip's head screwdriver and a black spudger (or equivalent tool)
Pièces
Aucune pièce spécifiée.
  1. Turn over camera to find 5 apparent screws.
    • Turn over camera to find 5 apparent screws.
  2. Remove all 5 screws from the bottom of the camera and store them carefully.
    • Remove all 5 screws from the bottom of the camera and store them carefully.
  3. Open battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of orange lever. Remove this screw.
    • Open battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of orange lever. Remove this screw.
  4. Rotate camera to find side panel with lanyard attachment. Detach side panel by lifting bottom corner slightly with the spudger.
    • Rotate camera to find side panel with lanyard attachment. Detach side panel by lifting bottom corner slightly with the spudger.
  5. Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
    • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  6. With back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
    • With back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
Ryan
Membre depuis le 12/04/2011
146 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 18-24, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,178
