Aller au contenu principal
Nikon Coolpix S6300 Buttons Replacement
Ce dont vous avez besoin
  1. Nikon Coolpix S6300 Buttons Replacement, Battery: étape 1, image 1 de 1
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Buttons Replacement: étape 2, image 1 de 1
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Buttons Replacement, Buttons: étape 3, image 1 de 3 Nikon Coolpix S6300 Buttons Replacement, Buttons: étape 3, image 2 de 3 Nikon Coolpix S6300 Buttons Replacement, Buttons: étape 3, image 3 de 3
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Buttons Replacement: étape 4, image 1 de 3 Nikon Coolpix S6300 Buttons Replacement: étape 4, image 2 de 3 Nikon Coolpix S6300 Buttons Replacement: étape 4, image 3 de 3
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Buttons Replacement: étape 5, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Buttons Replacement: étape 6, image 1 de 1
    • Remove the two clasp using a plastic spudger
    • Be careful when removing the clasp to prevent ripping of the clasp
  7. Nikon Coolpix S6300 Buttons Replacement: étape 7, image 1 de 1
    • You may now remove the internal panel of the buttons
Michael Lynch
Membre depuis le 08/31/15
396 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Remmell Fall 2015 Membre de l'équipe USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
5 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 707
