Introduction
The motherboard is located behind the LCD and rear panel of the camera. It is relatively accessible but does require the use of a soldering iron to completely disconnect it from the rest of the camera.
Ce dont vous avez besoin
Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right of the camera bottom.
Remove three 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom
Lift the battery cover and remove two 3 mm x 5 mm Phillips head screws.
Lift the tab on the ribbon connector and pull away the ribbon to expose a 4 mm x 4 mm Phillips head screw.
De-solder the red (upper), two grey (lower), red (lower), and blue (lower) wires from the motherboard.
Remove five 4 mm x 4 mm Phillips head screws holding the motherboard to the camera frame.
3 autres ont terminé cette réparation.
