Aller au contenu principal
Nikon D3000 Motherboard Replacement
Ce dont vous avez besoin
  1. Nikon D3000 Motherboard Replacement, Motherboard: étape 1, image 1 de 2 Nikon D3000 Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right of the camera bottom.
    • Remove three 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom
    • Lift the battery cover and remove two 3 mm x 5 mm Phillips head screws.
  2. Nikon D3000 Motherboard Replacement: étape 2, image 1 de 3 Nikon D3000 Motherboard Replacement: étape 2, image 2 de 3 Nikon D3000 Motherboard Replacement: étape 2, image 3 de 3
    • Remove the two 3 mm x 5.5 mm Phillips head screws from the either side of the viewfinder.
    • Remove four 3 mm x 5.5 mm Phillips head screws from the sides of the camera.
    • Remove two 3 mm x 4 mm Phillips head screws from under the SD card door.
  3. Nikon D3000 Motherboard Replacement: étape 3, image 1 de 2 Nikon D3000 Motherboard Replacement: étape 3, image 2 de 2
    • Use the following process for removing all ribbon connectors.
    • Lift the back of the camera and, using the blue prying tool, lift the tab from the LCD ribbon connector.
    • Slide the ribbon connector away from the bottom of the camera and remove the back cover containing the LCD to expose the motherboard.
  4. Nikon D3000 Motherboard Replacement: étape 4, image 1 de 2 Nikon D3000 Motherboard Replacement: étape 4, image 2 de 2
    • Soldering irons are hot; take all necessary precautions to not burn yourself or equipment.
    • Be sure to label each gray wire to be removed from the motherboard as they are the same color and can be mixed up during reassembly.
    • Lift the tab on the ribbon connector and pull away the ribbon to expose a 4 mm x 4 mm Phillips head screw.
    • De-solder the red (upper), two grey (lower), red (lower), and blue (lower) wires from the motherboard.
    • Remove five 4 mm x 4 mm Phillips head screws holding the motherboard to the camera frame.
  5. Nikon D3000 Motherboard Replacement: étape 5, image 1 de 2 Nikon D3000 Motherboard Replacement: étape 5, image 2 de 2
    • Lift the tabs and pull away the ribbon connectors shown .
    • Lift the motherboard and disconnect the grey connector from the bottom.
    • Disconnect and remove the motherboard.
3 autres ont terminé cette réparation.
Randall Heath
Membre depuis le 08/25/15
851 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 14-7, Meier Fall 2015 Membre de l'équipe USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 19
Total : 3,977
