Aller au contenu principal
Nikon D5000 Speaker Replacement
Ce dont vous avez besoin
  1. Nikon D5000 Speaker Replacement, Back Panel: étape 1, image 1 de 3 Nikon D5000 Speaker Replacement, Back Panel: étape 1, image 2 de 3 Nikon D5000 Speaker Replacement, Back Panel: étape 1, image 3 de 3
    • The battery door has been removed for clarity, but is not necessary. See this guide for how to remove it.
    • Unscrew the eight Phillips #00 screws on the back panel:
    • Two 2.5x6mm screws above the screen.
    • One 3x6mm screw on the upper part of each side (two total; right side shown).
    • One 3x7.5mm screw on the lower part of each side (two total).
    • Two 3x4.5mm screws on the bottom.
  2. Nikon D5000 Speaker Replacement: étape 2, image 1 de 3 Nikon D5000 Speaker Replacement: étape 2, image 2 de 3 Nikon D5000 Speaker Replacement: étape 2, image 3 de 3
    • Pull the back panel up, then tilt it back. There will be two cables still holding it on.
    • Doing this will also release the connector cover on the left side. Set it aside for now, but remember to reinstall it later.
    • Disconnect the ribbon cable by flipping the black tab up, then pulling the cable out.
    • This procedure also applies to all of the other ribbon cables in the D5000.
    • Pull out the other connector by lifting it up with tweezers, or by prying it out. Fingernails also work well.
  3. Nikon D5000 Speaker Replacement, Speaker: étape 3, image 1 de 2 Nikon D5000 Speaker Replacement, Speaker: étape 3, image 2 de 2
    • The speaker is mounted to the underside of the back panel. There is a a metal shield that holds it on.
    • Remove the four Phillips #00 screws securing the shield:
    • Three silver 3x4mm screws.
    • One black 3x3mm screw.
    • Remove the shield.
    • With the shield off, the navigation buttons and "Lv" button are free to move and rotate. Check alignment before replacement.
  4. Nikon D5000 Speaker Replacement: étape 4, image 1 de 1
    • Lift the blue tape on the ribbon cable.
    • Desolder the two leads to the speaker.
  5. Nikon D5000 Speaker Replacement: étape 5, image 1 de 1
    • Pry the speaker out of its cavity.
Jacob Rardin
Membre depuis le 04/14/14
1 390 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 13-28, Maness Spring 2014 Membre de l'équipe Cal Poly, Team 13-28, Maness Spring 2014
CPSU-MANESS-S14S13G28
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 11
Total : 949
