Aller au contenu principal
Nikon D5100 Battery Door Replacement
Ce dont vous avez besoin
  1. Nikon D5100 Battery Door Replacement, Battery Door: étape 1, image 1 de 3 Nikon D5100 Battery Door Replacement, Battery Door: étape 1, image 2 de 3 Nikon D5100 Battery Door Replacement, Battery Door: étape 1, image 3 de 3
    • Insert the battery into the battery compartment at the bottom of the camera.
  2. Nikon D5100 Battery Door Replacement: étape 2, image 1 de 3 Nikon D5100 Battery Door Replacement: étape 2, image 2 de 3 Nikon D5100 Battery Door Replacement: étape 2, image 3 de 3
    • Take the mending plate and place it over the threaded hole at the bottom of the camera.
    • Make sure the mending plate is covering the battery compartment.
    • Hold the mending plate in position.
  3. Nikon D5100 Battery Door Replacement: étape 3, image 1 de 3 Nikon D5100 Battery Door Replacement: étape 3, image 2 de 3 Nikon D5100 Battery Door Replacement: étape 3, image 3 de 3
    • While holding down the mending plate, take the screw and place it on top of the mending plate and over the threaded hole.
    • Push the screw into the threaded hole and turn clockwise to screw in.
    • Tighten the screw by using a screwdriver.
  4. Nikon D5100 Battery Door Replacement: étape 4, image 1 de 1
    • The metal bar should be attached and tightly secured.
  5. Nikon D5100 Battery Door Replacement: étape 5, image 1 de 2 Nikon D5100 Battery Door Replacement: étape 5, image 2 de 2
    • Turn on the camera to check that the battery is properly secure.
Ligne d'arrivée
Michelle Tran
Membre depuis le 02/24/15
101 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 23-1, Green Winter 2015 Membre de l'équipe Cal Poly, Team 23-1, Green Winter 2015
CPSU-GREEN-W15S23G1
4 membres
4 tutoriels rédigés
Un commentaire
My son broke the battery door and I kept it somewhere now it's gone
Chiaki - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 31
Total : 2,727
