Introduction
This guide shows to how replace a broken memory card door on the Nikon D5100. I ASSUME the procedure is the same for the D5000, D5200, D3000, D3100, and D3200. Your results may vary.
- D3100 differences: ***
Step 5 and 6 are differences for the D3100. The other steps still apply to the D3100.
Step 5 should be read before doing step 4 for the D3100.
Ce dont vous avez besoin
FIRST: open the memory card door and take a good long look at how the spring is installed. There are two "feet" coming off of the spring that need to be installed into two "insets" on the rear camera cover, this has to be done before you put the cover back on.
Remove the battery and memory card before you begin.
Remove 3 long screws behind the eye-piece (note that the one on the top-left is slightly longer than the rest and uses a different thread).
Then remove the sticker over the diopter (a pick tool is helpful here) and remove the silver screw behind it.
On the D3100 model there are only the two screws on the bottom, they are the two on the left in the picture from the previous step.
If there is a strap attached to the camera, remove the strap. There is a screw in the hole where the strap attaches. There is one screw on each side. I do not have a picture but they are easy to see. Remove both screws.
Install the new door making certain to put the spring back the way it was, with the two feet installed into the insets. Put the rear cover back on and test the memory card door to make sure it's working, then install all of the screws back where they went. Reapply adhesive to the rubber grips and diopter cover if desired.
30 autres ont terminé cette réparation.
19 commentaires
Thanks a lot! I used this guide to repair not the SD card door but the scroll wheel. After taking photos under very light rain it was not responding (in fact it turned briefly to the next value but returned, so I couldn't use it to change aperture, shutter speed, etc. via the scroll wheel). I opened the rear cover and sprayed a little contact cleaner and compressed air right into the scroll wheel and after that the problem was solved. Thanks again!
Thank you so much for posting this!! I was gutted when I snapped my SD card door and it wasn't covered by warranty. Sent an online estimate to a "camera repair" company and got quoted £48 plus postage to fix (£20 for a new door). Rang Nikon spares who sent me a new door for £2.95!!( £2 postage). But fiddley taking all the screws out but between hubby and I , we did it! Saved a fortune, took 15 minutes - camera works perfectly! Thanks again.
Do you have the contact info for Rang Nikon spares? I can not seem to locate them.
