Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide will show you how to properly remove your camera's battery.
Outils
Aucun outil spécifié.
Pièces
  1. First, power off the device.
    • First, power off the device.
  2. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  3. Set the camera so that it is sitting on its side. Open the battery compartment door by sliding the release button towards the lens. This will cause the door to "pop" open slightly
    • Set the camera so that it is sitting on its side.
    • Open the battery compartment door by sliding the release button towards the lens.
    • This will cause the door to "pop" open slightly
  4. Now lift open the battery compartment door. Push the yellow tab lock towards the center to release the battery.
    • Now lift open the battery compartment door.
    • Push the yellow tab lock towards the center to release the battery.
    • This will cause the battery to jump up as there is a spring at the bottom.
    • Pull straight out, slowly on the battery.
    • Make sure you pay attention to which way the battery goes .
Daniel Eagan
Membre depuis le 10/02/2016
561 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 4-4, Lacy Spring 2016 Membre de l'équipe USF Tampa, Team 4-4, Lacy Spring 2016
USFT-LACY-S16S4G4
3 membres
6 tutoriels rédigés
This is my kind of fixing )
Loic - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 806
