Introduction
Remove the rear cover assembly to access the LCD and other components.
Outils
Pièces
Aucune pièce spécifiée.
Use your finger tip to pull the battery release tab toward the center of the D70.
Open the battery door and rotate it away from the bottom cover.
Remove the following eight screws securing the bottom cover to the D70:
Six 5.8 mm Phillips screws
One 10.7 mm Phillips screws
One 8.2 mm Phillips screws
Remove the two 4.8 mm Phillips screws securing the battery side of the rear cover to the D70.
10 autre(s) ont terminé cette réparation.
