Aller au contenu principal
Nikon D7100 Headphone/Microphone Replacement
Ce dont vous avez besoin
  1. Nikon D7100 Headphone/Microphone Replacement, LCD Screen: étape 1, image 1 de 1
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
  2. Nikon D7100 Headphone/Microphone Replacement: étape 2, image 1 de 1
    • Remove the 3 screws under the battery flap and remove the bottom cover.
  3. Nikon D7100 Headphone/Microphone Replacement: étape 3, image 1 de 1
    • Remove the 2 screws inside the camera on the back corners.
  4. Nikon D7100 Headphone/Microphone Replacement: étape 4, image 1 de 1
    • Open the HDMI flap and remove the 2 screws.
  5. Nikon D7100 Headphone/Microphone Replacement: étape 5, image 1 de 1
    • Remove the screw next to the camera strap loop.
  6. Nikon D7100 Headphone/Microphone Replacement: étape 6, image 1 de 1
    • Remove the 2 screws on each side of the view finder.
  7. Nikon D7100 Headphone/Microphone Replacement: étape 7, image 1 de 1
    • Remove the 2 screws above and below the SD card flap.
  8. Nikon D7100 Headphone/Microphone Replacement: étape 8, image 1 de 1
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
  9. Nikon D7100 Headphone/Microphone Replacement: étape 9, image 1 de 2 Nikon D7100 Headphone/Microphone Replacement: étape 9, image 2 de 2
    • Remove the Diopter adjustment control sticker and remove the screw under it.
  10. Nikon D7100 Headphone/Microphone Replacement: étape 10, image 1 de 1
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
  11. Nikon D7100 Headphone/Microphone Replacement: étape 11, image 1 de 1
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
  12. Nikon D7100 Headphone/Microphone Replacement: étape 12, image 1 de 2 Nikon D7100 Headphone/Microphone Replacement: étape 12, image 2 de 2
    • Unscrew all 16 screws around the back plate of the camera.
  13. Nikon D7100 Headphone/Microphone Replacement: étape 13, image 1 de 1
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
  14. Nikon D7100 Headphone/Microphone Replacement, Motherboard: étape 14, image 1 de 1
    • Undo the 5 ribbon cable connectors by flipping the latches up with a plastic spudger.
  15. Nikon D7100 Headphone/Microphone Replacement: étape 15, image 1 de 1
    • Remove the black 4 pin connector by pulling it out of the connector.
  16. Nikon D7100 Headphone/Microphone Replacement: étape 16, image 1 de 1
    • Remove the 7 screws holding the motherboard in place.
  17. Nikon D7100 Headphone/Microphone Replacement: étape 17, image 1 de 1
    • This is what you should see after removing the motherboard.
  18. Nikon D7100 Headphone/Microphone Replacement, Headphone and Microphone Module: étape 18, image 1 de 1
    • After following the guide to remove the back LCD screen from the motherboard, remove the 2 marked screws.
Wesley Eveld
Membre depuis le 02/20/18
731 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S11-G6, Cheng Spring 2018 Membre de l'équipe USF Tampa, Team S11-G6, Cheng Spring 2018
USFT-CHENG-S18S11G6
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 18
Total : 1,043
