Aller au contenu principal
Nikon D80 Motherboard Replacement
Ce dont vous avez besoin
  1. Nikon D80 Motherboard Replacement, Main Board: étape 1, image 1 de 2 Nikon D80 Motherboard Replacement, Main Board: étape 1, image 2 de 2
    • Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
  2. Nikon D80 Motherboard Replacement: étape 2, image 1 de 3 Nikon D80 Motherboard Replacement: étape 2, image 2 de 3 Nikon D80 Motherboard Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Motherboard Replacement: étape 3, image 1 de 3 Nikon D80 Motherboard Replacement: étape 3, image 2 de 3 Nikon D80 Motherboard Replacement: étape 3, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the six 3.7 mm screws.
    • Remove the back plate that covers the main board.
  4. Nikon D80 Motherboard Replacement: étape 4, image 1 de 2 Nikon D80 Motherboard Replacement: étape 4, image 2 de 2
    • Use a Phillips #00 screwdriver to unscrew the 2.3 mm screw.
  5. Nikon D80 Motherboard Replacement: étape 5, image 1 de 1
    • Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
    • Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
    • Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
    • Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
    • Disconnect the main board from the two ports on the left by pulling the main board to the right.
  6. Nikon D80 Motherboard Replacement: étape 6, image 1 de 3 Nikon D80 Motherboard Replacement: étape 6, image 2 de 3 Nikon D80 Motherboard Replacement: étape 6, image 3 de 3
    • Using the soldering iron, disconnect the four wires soldered to the main board.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Be careful when using the hot soldering iron. Move the ribbon cable out of the way as well; it is easy to burn it or yourself when using the iron.
    • Remove the main board.
  7. Nikon D80 Motherboard Replacement, Motherboard: étape 7, image 1 de 3 Nikon D80 Motherboard Replacement, Motherboard: étape 7, image 2 de 3 Nikon D80 Motherboard Replacement, Motherboard: étape 7, image 3 de 3
    • Unscrew the three 2.3 mm screws using a Phillips #00 screwdriver.
    • Use the Phillips #00 screwdriver to unscrew the three 4.7 mm screws.
    • Gently remove the motherboard.
3 autres ont terminé cette réparation.
Sara Martin
Membre depuis le 10/09/17
586 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Leahy Fall 2017 Membre de l'équipe USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 41
Total : 3,527
