Introduction
After extended use, the motherboard of a camera can often stop working. This guide explains how to replace the motherboard of a Nikon D80 camera. For safety purposes, please remove the battery before working with any electronic components.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Ce dont vous avez besoin
Using a Phillips #00 screwdriver, remove the four 6.2 mm screws from the left and right sides of the outer cover.
Use tweezers to gently flip the small locking flaps of the zero force insertion connectors up.
Pull the bottom orange connector cable out of the zero force insertion connector using the tweezers.
Pull the top orange connector cable out of the zero force insertion connector using the tweezers.
Remove the ribbon cables by gently pulling them away from the no-fuss ribbon cable connectors.
Disconnect the main board from the two ports on the left by pulling the main board to the right.
Unscrew the three 2.3 mm screws using a Phillips #00 screwdriver.
Use the Phillips #00 screwdriver to unscrew the three 4.7 mm screws.
Gently remove the motherboard.
3 autres ont terminé cette réparation.
