Aller au contenu principal
Nikon D80 Rear LCD Screen Replacement
Ce dont vous avez besoin
  1. Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: étape 1, image 1 de 3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: étape 1, image 2 de 3 Nikon D80 Rear LCD Screen Replacement, Rear LCD Screen: étape 1, image 3 de 3
    • Using a Philips #00 screwdriver, remove the four 6.2mm from the left and right sides of the outer cover.
  2. Nikon D80 Rear LCD Screen Replacement: étape 2, image 1 de 3 Nikon D80 Rear LCD Screen Replacement: étape 2, image 2 de 3 Nikon D80 Rear LCD Screen Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to gently flip the small locking flap of the zero force insertion connector up.
    • Pull the orange connector cable away from the main body of the camera using the tweezers.
    • Remove the back cover.
  3. Nikon D80 Rear LCD Screen Replacement: étape 3, image 1 de 2 Nikon D80 Rear LCD Screen Replacement: étape 3, image 2 de 2
    • Using a Philips #00 screwdriver, remove the three 4.3 mm screws by rotating screwdriver to the left.
    • Use the Phillips #00 screwdriver to remove the two 3.4 mm screws.
  4. Nikon D80 Rear LCD Screen Replacement: étape 4, image 1 de 2 Nikon D80 Rear LCD Screen Replacement: étape 4, image 2 de 2
    • Using blunt tweezers, gently flip the small locking flap of the zero force insertion connector up for both connectors.
    • Use blunt tweezers to pull the left ribbon connector out of the zero insertion force connector.
    • Using the same tweezers, pull the right ribbon connector out of the zero insertion force connector.
  5. Nikon D80 Rear LCD Screen Replacement: étape 5, image 1 de 2 Nikon D80 Rear LCD Screen Replacement: étape 5, image 2 de 2
    • Slide out the LCD screen by pulling towards the right.
    • Remove the LCD screen.
    • The buttons beside the screen fall out easily. Remember where they were and put them back when finished with the screen.
Sara Martin
Membre depuis le 10/09/17
586 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Leahy Fall 2017 Membre de l'équipe USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 33
Total : 2,992
