Aller au contenu principal
Nikon D90 Flash Hinge Spring Replacement
Ce dont vous avez besoin
  1. Nikon D90 Flash Hinge Spring Replacement, Open the Flash: étape 1, image 1 de 3 Nikon D90 Flash Hinge Spring Replacement, Open the Flash: étape 1, image 2 de 3 Nikon D90 Flash Hinge Spring Replacement, Open the Flash: étape 1, image 3 de 3
    • Use a plastic opening tool to lift up the flash.
  2. Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: étape 2, image 1 de 2 Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: étape 2, image 2 de 2
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: étape 3, image 1 de 3 Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: étape 3, image 2 de 3 Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: étape 3, image 3 de 3
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  4. Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: étape 4, image 1 de 2 Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: étape 4, image 2 de 2
    • Using a PH00 screwdriver, loosen the 3.3 mm Phillips screw from the spring.
  5. Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: étape 5, image 1 de 2 Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: étape 5, image 2 de 2
    • Use a plastic opening tool and carefully pry up the spring arm.
    • Doing this with release the pressure of the spring.
  6. Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: étape 6, image 1 de 2 Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: étape 6, image 2 de 2
    • Finish removing the screw holding the spring in place.
    • The spring can now be removed and replaced.
Matthew Grota
Membre depuis le 10/16/14
586 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Membre de l'équipe UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 membres
6 tutoriels rédigés
Un commentaire
These are great tutorials,
I was looking for one on how to fix the pop up flash not locking down,
It was bought second hand and dropped on the logo,
The front panel needed to be replaced,
Now for the Flash that is constantly up.
Any links? jjryzler@gmail.com
Ryad Arlan - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 6
Total : 4,082
