Ce dont vous avez besoin
Use a spudger to lift the black tab on the ZIF connector.
Disconnect the ribbon cables from their respective ZIF connectors on the logic board.
Peel back the yellow tape covering the cable connector on the back of the casing you removed.
Using either the iOpener or a heat gun, heat the rear LCD glass enough to melt the adhesive holding it on.
9 autres ont terminé cette réparation.
