Introduction
The communication board sends information about the aperture and focus of the lens. If you are having trouble with focus or aperture, then there may be a problem with the communication board.
Pièces
Aucune pièce nécessaire.
Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
Ajouter un commentaire
Remove lens mount from the camera.
  • Remove lens mount from the camera.
  • Be careful not to lose any of the three loose pieces that are under the lens mount.
  • Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
  • Make sure you remember the orientation of the metal ring so that it is easier to put back in the device later.
  • Use 00 Phillips head screwdriver to remove the screw from the bottom of the front black case.
  • Use 00 Phillips head screwdriver to remove the screws from the top case (6 in all).
  • Remove the front case from the camera.
  • There is a black plastic ring in the case. Be sure not to remove it, as it can be difficult to put back.
  • Use a 00 Phillips head screwdriver to remove the screws from either side of the communication board.
  • Desolder the wires and remove them from the communication board.
  • Note: If you are unfamiliar with soldering techniques, click here for a guide.
5 autre(s) ont terminé cette réparation.
Zachary Phillips
Membre depuis le 08/04/2011
205 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 25-26, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-26, Garner Spring 2011
CPSU-GARNER-S11S25G26
3 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 23
Total : 4,039
