Aller au contenu principal
Ninja Coffee Bar® Single-Serve System Frother Replacement
Ce dont vous avez besoin
  1. Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: étape 1, image 1 de 2 Ninja Coffee Bar® Single-Serve System Frother Replacement, Frother: étape 1, image 2 de 2
    • Remove four 6mm #1 Phillips head screws from under the basket area.
    • Remove the single 6mm #1 Phillips head screw from the side of the unit.
  2. Ninja Coffee Bar® Single-Serve System Frother Replacement: étape 2, image 1 de 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: étape 2, image 2 de 2
    • Gently pry the upper cover off the unit above the brew basket and above the water reservoir base and along the side of the upper cover.
  3. Ninja Coffee Bar® Single-Serve System Frother Replacement: étape 3, image 1 de 2 Ninja Coffee Bar® Single-Serve System Frother Replacement: étape 3, image 2 de 2
    • Remove the single 6mm #1 Phillips head screw from the top of the unit. (The two smaller screws should remain attached.)
    • Using an extension, remove the two 6mm Phillips head screws from the side of the frother motor pivot.
  4. Ninja Coffee Bar® Single-Serve System Frother Replacement: étape 4, image 1 de 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: étape 4, image 2 de 3 Ninja Coffee Bar® Single-Serve System Frother Replacement: étape 4, image 3 de 3
    • Pinch power connector and pull lighly to separate.
    • Pull motor straight up to separate from unit.
CJ Berg
Membre depuis le 11/05/18
444 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G4
3 membres
5 tutoriels rédigés
Un commentaire
Awesome write-up. But does anyone know where a replacement frother arm can be purchased?
clarkwolfe - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 16
Total : 1,480
