Introduction
Changing the tubes when the Ninja Coffee Bar® Single-Serve System leaks water from the bottom will require some time but can fix a few problems. Ensure the device is in a secure open area where you will not lose any screws because they are small. You will want the magnetic pad provided in the iFixit tool kit. Warning: be careful when removing the protective plate because many wires cannot be disconnected.
Before beginning the repair, turn off the coffee maker and unplug the device from the power outlet.
Ce dont vous avez besoin
Remove the eight 6 mm screws using the Phillips #1 screwdriver.
Remove the bottom cover.
