Aller au contenu principal
Ninja Coffee Bar® Single-Serve System Water Heater Replacement
Ce dont vous avez besoin
  1. Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Valve Tubes: étape 1, image 1 de 2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Valve Tubes: étape 1, image 2 de 2
    • Remove the eight 6 mm screws using the Phillips #1 screwdriver.
    • Remove the bottom cover.
  2. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: étape 2, image 1 de 1
    • Remove the three 6 mm screws with the Phillips #1 screwdriver.
    • Remove the plastic cover.
  3. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: étape 3, image 1 de 1
    • Detach the valve tubes from the valve by squeezing the pins and pulling them away from the valve.
  4. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: étape 4, image 1 de 1
    • Detach the valve tubes from the device by pinching the pins and sliding the valve tubes off.
  5. Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Water Heater: étape 5, image 1 de 2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement, Water Heater: étape 5, image 2 de 2
    • Unscrew the four 6mm #1 Phillips head screws from the underside of the basket area.
    • Remove the single 6mm #1 Phillips-head screw from the side of the unit.
  6. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: étape 6, image 1 de 2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: étape 6, image 2 de 2
    • Slowly pry the upper cover away from the unit on top of the brew basket, and near the base of the water reservoir along the side of the upper cover.
  7. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: étape 7, image 1 de 1
    • Separate hose from upper nozzle by squeezing the clamp and pulling the hose down slightly.
  8. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: étape 8, image 1 de 2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: étape 8, image 2 de 2
    • Using a #1 Phillips head screwdriver with an extension, remove three 6mm screws holding the heater to the unit.
  9. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: étape 9, image 1 de 1
    • Remove heater from unit.
  10. Ninja Coffee Bar® Single-Serve System Water Heater Replacement: étape 10, image 1 de 2 Ninja Coffee Bar® Single-Serve System Water Heater Replacement: étape 10, image 2 de 2
    • Squeeze clip and separate signal wiring.
    • Using wire stripper/crimping tool, uncrimp wiring connectors
    • Wiring connectors are sealed together making them difficult to disconnect. Cutting and rewiring should be considered.
CJ Berg
Membre depuis le 11/05/18
444 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G4, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G4
3 membres
5 tutoriels rédigés
Un commentaire
Where can I buy the water heater?
lrstorey1 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 20
Total : 1,066
