Aller au contenu principal
Ninja Coffee Bar CF080 Brewer Head Replacement
Ce dont vous avez besoin
  1. Ninja Coffee Bar CF080 Brewer Head Replacement, Brewer Head: étape 1, image 1 de 1
    • Face the coffee machine in front of you.
    • Make sure that the coffee machine is unplugged.
    • Remove the glass carafe as it will not be needed.
  2. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 2, image 1 de 1
    • Firmly grab the tab sticking out from the head of the brewer.
  3. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 3, image 1 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 3, image 2 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 3, image 3 de 3
    • With little force, pull the tab of the brewer head in reverse direction.
  4. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 4, image 1 de 1
    • Slide off the head in the direction away from the machine.
    • If the head does not come off smoothly by sliding, give a firm tug in the same direction.
  5. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 5, image 1 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 5, image 2 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 5, image 3 de 3
    • Hold the head in the same position and lift it forward until the Ninja is facing upward toward the ceiling.
  6. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 6, image 1 de 1
    • Now the brewer head is positioned to where you can seeing the bottom.
  7. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 7, image 1 de 2 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 7, image 2 de 2
    • Remove the screw with a Phillips #1 screwdriver.
    • Use Phillips #1 screwdriver.
    • Along will come a small black screw cover and spring
  8. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 8, image 1 de 1
    • Twist the black lid on top clockwise until it is completely detached.
  9. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 9, image 1 de 1
    • With the black upper lid detached, a smaller black cover can be removed without effort.
  10. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 10, image 1 de 2 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 10, image 2 de 2
    • Remove the 6 screws from the seal with a Phillips #1 screwdriver.
  11. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 11, image 1 de 1
    • Once all screws are detached from the brewer head, it will be separated into two pieces leaving the filter.
Elizabeth Nguyen
Membre depuis le 09/11/17
416 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team S1-G1, Bruce Fall 2017 Membre de l'équipe CSU Fullerton, Team S1-G1, Bruce Fall 2017
CSUF-BRUCE-F17S1G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 986
