Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ninja Coffee Bar CF080 Brewer Head Replacement
Ce dont vous avez besoin
    1. Ninja Coffee Bar CF080 Brewer Head Replacement, Brewer Head: étape 1, image 1 de 1
      • Face the coffee machine in front of you.
      • Make sure that the coffee machine is unplugged.
      • Remove the glass carafe as it will not be needed.
      Demander à FixBot
      Ajouter un commentaire
    2. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 2, image 1 de 1
      • Firmly grab the tab sticking out from the head of the brewer.
      Demander à FixBot
    3. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 3, image 1 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 3, image 2 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 3, image 3 de 3
      • With little force, pull the tab of the brewer head in reverse direction.
      Demander à FixBot
    4. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 4, image 1 de 1
      • Slide off the head in the direction away from the machine.
      • If the head does not come off smoothly by sliding, give a firm tug in the same direction.
      Demander à FixBot
    5. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 5, image 1 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 5, image 2 de 3 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 5, image 3 de 3
      • Hold the head in the same position and lift it forward until the Ninja is facing upward toward the ceiling.
      Demander à FixBot
    6. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 6, image 1 de 1
      • Now the brewer head is positioned to where you can seeing the bottom.
      Demander à FixBot
    7. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 7, image 1 de 2 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 7, image 2 de 2
      • Remove the screw with a Phillips #1 screwdriver.
      • Use Phillips #1 screwdriver.
      • Along will come a small black screw cover and spring
      Demander à FixBot
    8. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 8, image 1 de 1
      • Twist the black lid on top clockwise until it is completely detached.
      Demander à FixBot
    9. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 9, image 1 de 1
      • With the black upper lid detached, a smaller black cover can be removed without effort.
      Demander à FixBot
    10. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 10, image 1 de 2 Ninja Coffee Bar CF080 Brewer Head Replacement: étape 10, image 2 de 2
      • Remove the 6 screws from the seal with a Phillips #1 screwdriver.
      Demander à FixBot
    11. Ninja Coffee Bar CF080 Brewer Head Replacement: étape 11, image 1 de 1
      • Once all screws are detached from the brewer head, it will be separated into two pieces leaving the filter.
      Demander à FixBot
Elizabeth Nguyen
Membre depuis le 09/11/17
416 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team S1-G1, Bruce Fall 2017 Membre de l'équipe CSU Fullerton, Team S1-G1, Bruce Fall 2017
CSUF-BRUCE-F17S1G1
4 membres
60 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 30
30 derniers jours : 70
Total : 1,566
