Aller au contenu principal
Ninja Coffee Bar CF080 Heated Plate Replacement
Ce dont vous avez besoin
  1. Ninja Coffee Bar CF080 Heated Plate Replacement, Heated Plate: étape 1, image 1 de 1
    • Face the machine bottom towards you.
  2. Ninja Coffee Bar CF080 Heated Plate Replacement: étape 2, image 1 de 2 Ninja Coffee Bar CF080 Heated Plate Replacement: étape 2, image 2 de 2
    • Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
    • Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
  3. Ninja Coffee Bar CF080 Heated Plate Replacement: étape 3, image 1 de 3 Ninja Coffee Bar CF080 Heated Plate Replacement: étape 3, image 2 de 3 Ninja Coffee Bar CF080 Heated Plate Replacement: étape 3, image 3 de 3
    • With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
  4. Ninja Coffee Bar CF080 Heated Plate Replacement: étape 4, image 1 de 3 Ninja Coffee Bar CF080 Heated Plate Replacement: étape 4, image 2 de 3 Ninja Coffee Bar CF080 Heated Plate Replacement: étape 4, image 3 de 3
    • Remove the bottom board with moderate force.
  5. Ninja Coffee Bar CF080 Heated Plate Replacement: étape 5, image 1 de 1
    • Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
    • Four screws on each side, two silver secures to remove the securers, located on the sliver bar holding the heated plate (one on each end).
  6. Ninja Coffee Bar CF080 Heated Plate Replacement: étape 6, image 1 de 1
    • Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
    • The silver bar will fall off once screws are removed.
  7. Ninja Coffee Bar CF080 Heated Plate Replacement: étape 7, image 1 de 2 Ninja Coffee Bar CF080 Heated Plate Replacement: étape 7, image 2 de 2
    • Remove the heated plate from the machine with easy glide.
Elizabeth Nguyen
Membre depuis le 09/11/17
416 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team S1-G1, Bruce Fall 2017 Membre de l'équipe CSU Fullerton, Team S1-G1, Bruce Fall 2017
CSUF-BRUCE-F17S1G1
4 membres
5 tutoriels rédigés
Un commentaire
Where do you get a replacement plate at?
Timothy Sick - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 795
