Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Ninja Coffee Bar CF080 Power Module Replacement
Ce dont vous avez besoin
    1. Ninja Coffee Bar CF080 Power Module Replacement, Heated Plate: étape 1, image 1 de 1
      • Face the machine bottom towards you.
      Demander à FixBot
      Ajouter un commentaire
    2. Ninja Coffee Bar CF080 Power Module Replacement: étape 2, image 1 de 2 Ninja Coffee Bar CF080 Power Module Replacement: étape 2, image 2 de 2
      • Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
      • Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
      Demander à FixBot
    3. Ninja Coffee Bar CF080 Power Module Replacement: étape 3, image 1 de 3 Ninja Coffee Bar CF080 Power Module Replacement: étape 3, image 2 de 3 Ninja Coffee Bar CF080 Power Module Replacement: étape 3, image 3 de 3
      • With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
      Demander à FixBot
    4. Ninja Coffee Bar CF080 Power Module Replacement: étape 4, image 1 de 3 Ninja Coffee Bar CF080 Power Module Replacement: étape 4, image 2 de 3 Ninja Coffee Bar CF080 Power Module Replacement: étape 4, image 3 de 3
      • Remove the bottom board with moderate force.
      Demander à FixBot
    5. Ninja Coffee Bar CF080 Power Module Replacement: étape 5, image 1 de 1
      • Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
      • Four screws on each side, two silver secures to remove the securers, located on the sliver bar holding the heated plate (one on each end).
      Demander à FixBot
    6. Ninja Coffee Bar CF080 Power Module Replacement: étape 6, image 1 de 1
      • Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
      • The silver bar will fall off once screws are removed.
      Demander à FixBot
    7. Ninja Coffee Bar CF080 Power Module Replacement: étape 7, image 1 de 2 Ninja Coffee Bar CF080 Power Module Replacement: étape 7, image 2 de 2
      • Remove the heated plate from the machine with easy glide.
      Demander à FixBot
    1. Ninja Coffee Bar CF080 Power Module Replacement, Power Module: étape 8, image 1 de 3 Ninja Coffee Bar CF080 Power Module Replacement, Power Module: étape 8, image 2 de 3 Ninja Coffee Bar CF080 Power Module Replacement, Power Module: étape 8, image 3 de 3
      • Remove the nine 0.5cm screws with Phillips #2 screwdriver.
      • Some screws are harder to see due to how deep the holes are.
      • Recommend using Extender 4 with Phillips #2 screwdriver to help unscrew the screws within the deep holes of the machine.
      Demander à FixBot
    2. Ninja Coffee Bar CF080 Power Module Replacement: étape 9, image 1 de 2 Ninja Coffee Bar CF080 Power Module Replacement: étape 9, image 2 de 2
      • Remove the two 0.6cm with Phillips #2 screwdriver.
      Demander à FixBot
    3. Ninja Coffee Bar CF080 Power Module Replacement: étape 10, image 1 de 3 Ninja Coffee Bar CF080 Power Module Replacement: étape 10, image 2 de 3 Ninja Coffee Bar CF080 Power Module Replacement: étape 10, image 3 de 3
      • Detach various colored cords from one another, using both hands to place thumb and index finger to hold each grip then separate by pulling with the degree of force.
      • There with be 1 blue, 1 black, 1 red and 2 white.
      Demander à FixBot
    4. Ninja Coffee Bar CF080 Power Module Replacement: étape 11, image 1 de 2 Ninja Coffee Bar CF080 Power Module Replacement: étape 11, image 2 de 2
      • Remove the black board by maneuvering it through the cords.
      Demander à FixBot
    5. Ninja Coffee Bar CF080 Power Module Replacement: étape 12, image 1 de 3 Ninja Coffee Bar CF080 Power Module Replacement: étape 12, image 2 de 3 Ninja Coffee Bar CF080 Power Module Replacement: étape 12, image 3 de 3
      • Grip the bottom end of the panel and pull it towards you to remove the module from the machine.
      Demander à FixBot
    6. Ninja Coffee Bar CF080 Power Module Replacement: étape 13, image 1 de 2 Ninja Coffee Bar CF080 Power Module Replacement: étape 13, image 2 de 2
      • Remove the three 0.6cm screws with Phillips #1 screwdriver.
      • They are in the black holes, 1 at the top and two at the bottom.
      Demander à FixBot
    7. Ninja Coffee Bar CF080 Power Module Replacement: étape 14, image 1 de 1
      • Remove the black board attached to the module.
      Demander à FixBot
2 autres ont terminé cette réparation.
Elizabeth Nguyen
Membre depuis le 09/11/17
416 Réputation
3 tutoriels rédigés
Équipe
CSU Fullerton, Team S1-G1, Bruce Fall 2017 Membre de l'équipe CSU Fullerton, Team S1-G1, Bruce Fall 2017
CSUF-BRUCE-F17S1G1
4 membres
60 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 31
30 derniers jours : 63
Total : 4,395
