Introduction
The water pump facilitates the motion of water from the reservoir to the drip area. This guide shows how to replace it.
Ce dont vous avez besoin
Using wire strippers, strip the cut wires from your coffee machine near their cut ends to expose 2 cm of metal conductor from each.
Use a similar procedure to strip the wires from your replacement heating element. Using wire strippers, expose 2 cm of metal conductor from the ends of the wires.
Prepare two crimp connectors by filling them with dielectric grease.
Use a crimp connector to connect a stripped end of the wire leading from the replacement heating element to the stripped end of the corresponding wire from the coffee maker.
Using a second crimp connector, repeat for the remaining pair of stripped wires.
Using the appropriate crimping tool, crimp the connectors.
Locate the water pump in the interior of your device.
Squeeze and remove the clamps securing the tubes that are connected to the side of the water pump.
2 autres ont terminé cette réparation.
