Introduction
On your Ninja Foodi SP101, the bottom panel allows you greater access to the interior of the device. This bottom panel also functions as a net to capture crumbs, grease, and other food particles. If the bottom panel needs to be removed for replacement/cleaning, follow this guide.
Ce dont vous avez besoin
Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
