Aller au contenu principal
Ninja Foodi SP101 Motor Replacement
Ce dont vous avez besoin
  1. Ninja Foodi SP101 Motor Replacement, Feet: étape 1, image 1 de 2 Ninja Foodi SP101 Motor Replacement, Feet: étape 1, image 2 de 2
    • Use a TR10 screwdriver to remove the four 11mm screws holding the black lever bar in place.
  2. Ninja Foodi SP101 Motor Replacement: étape 2, image 1 de 1
    • Remove the black lever bar.
  3. Ninja Foodi SP101 Motor Replacement, Side Panels: étape 3, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the three 8mm screws on each side of the back panel.
  4. Ninja Foodi SP101 Motor Replacement: étape 4, image 1 de 2 Ninja Foodi SP101 Motor Replacement: étape 4, image 2 de 2
    • Flip the device upside down and open the bottom panel.
    • Remove the five 8 mm screws on each side of the interior using a Phillips #1 screwdriver.
  5. Ninja Foodi SP101 Motor Replacement: étape 5, image 1 de 3 Ninja Foodi SP101 Motor Replacement: étape 5, image 2 de 3 Ninja Foodi SP101 Motor Replacement: étape 5, image 3 de 3
    • Remove the control side panel.
    • Lift the siding outward to remove the metal tab connection on the bottom.
  6. Ninja Foodi SP101 Motor Replacement: étape 6, image 1 de 2 Ninja Foodi SP101 Motor Replacement: étape 6, image 2 de 2
    • Lift the handle and pull the side panel out.
    • Remove the handle side panel.
  7. Ninja Foodi SP101 Motor Replacement, Motor: étape 7, image 1 de 3 Ninja Foodi SP101 Motor Replacement, Motor: étape 7, image 2 de 3 Ninja Foodi SP101 Motor Replacement, Motor: étape 7, image 3 de 3
    • Open the bottom door.
    • Remove the five 8 mm screws located on the control panel side using a Phillips #1 screwdriver.
  8. Ninja Foodi SP101 Motor Replacement: étape 8, image 1 de 1
    • Remove the four 1 mm screws with a Phillips #1 screwdriver.
    • Remove the motor from the device.
ben
Membre depuis le 01/30/24
395 Réputation
3 tutoriels rédigés
Équipe
Utah Tech University, Team 1-4, McMurrin Spring 2024 Membre de l'équipe Utah Tech University, Team 1-4, McMurrin Spring 2024
UTAHTECH-MCMURRIN-S24S1G4
2 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 25
Total : 55
