Aller au contenu principal
Ninja Mega Kitchen System BL770 Circuit Board Replacement
Ce dont vous avez besoin
  1. Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Base: étape 1, image 1 de 2 Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Base: étape 1, image 2 de 2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Circuit Board Replacement: étape 2, image 1 de 1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Circuit Board Replacement: étape 3, image 1 de 3 Ninja Mega Kitchen System BL770 Circuit Board Replacement: étape 3, image 2 de 3 Ninja Mega Kitchen System BL770 Circuit Board Replacement: étape 3, image 3 de 3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Circuit Board Replacement: étape 4, image 1 de 1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Board: étape 5, image 1 de 2 Ninja Mega Kitchen System BL770 Circuit Board Replacement, Circuit Board: étape 5, image 2 de 2
    • Cautiously desolder all the wires connecting the circuit board to the unit.
    • Carefully slide the circuit board free of the wires are place the new board in.
    • Solder the wires back onto the new board, keeping track of which wire goes where in order for your unit to properly function.
5 autres ont terminé cette réparation.
Tommee Walker
Membre depuis le 08/22/17
823 Réputation
6 tutoriels rédigés
Équipe
14 commentaires
Thanks for the post… this is helping me with my blender…. by any chance do you have a better picture of the resistor on the back of the circuit board… it seems to be a yellow blue blue gold sequence resistor… my board just burned that resistor and I am trying to find and replace just that resistor if possible… but I am not sure of the colors so I can locate the right now.
Jose Gonzalez - Réponse
Does somebody know where can I buy this circuit board ??
castro_73 - Réponse
Anyone know the chip on this circuit board?? Proprietary I assume??
Nathan Walter - Réponse
Great info but i’m looking to purchase a replacement circuit board for my ninja blender and can not find one. Any ideas?
Rich - Réponse
hi,, i need to know the reference of transistor with position Q2. in the main board BL770 , thanks.
kolin camacho - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 19
30 derniers jours : 103
Total : 4,571
