Aller au contenu principal
Ninja Mega Kitchen System BL770 Power Cord Replacement
Ce dont vous avez besoin
  1. Ninja Mega Kitchen System BL770 Power Cord Replacement, Circuit Base: étape 1, image 1 de 2 Ninja Mega Kitchen System BL770 Power Cord Replacement, Circuit Base: étape 1, image 2 de 2
    • Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
    • Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
  2. Ninja Mega Kitchen System BL770 Power Cord Replacement: étape 2, image 1 de 1
    • Carefully remove the second layer from the base. You will not need a screwdriver for this step.
  3. Ninja Mega Kitchen System BL770 Power Cord Replacement: étape 3, image 1 de 3 Ninja Mega Kitchen System BL770 Power Cord Replacement: étape 3, image 2 de 3 Ninja Mega Kitchen System BL770 Power Cord Replacement: étape 3, image 3 de 3
    • Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
    • Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
    • Carefully lift the base up from the rest of the blender.
  4. Ninja Mega Kitchen System BL770 Power Cord Replacement: étape 4, image 1 de 1
    • Remove 4 screws (11mm, 4mm head) connecting the circuit board to the base.
  5. Ninja Mega Kitchen System BL770 Power Cord Replacement, Power Cord: étape 5, image 1 de 2 Ninja Mega Kitchen System BL770 Power Cord Replacement, Power Cord: étape 5, image 2 de 2
    • Check that the two red wires shown in the photos are properly soldered to the circuit board.
    • If they seem damaged, resolder the wires to the board.
    • If this doesn't solve the issue, proceed to step 6.
  6. Ninja Mega Kitchen System BL770 Power Cord Replacement: étape 6, image 1 de 1
    • If the 2 wires in the previous step are connected, it's time to check the 2nd area.
    • Remove the plastic covers and check that the wires are soldered correctly.
Tommee Walker
Membre depuis le 08/22/17
823 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 19
Total : 972
